Solved by tvollaro. Go to Solution.
Do you mind posting the AXM file or maybe just an image of your project so I can get an idea of what type of geometry you are attempting? I am looking closely at 3D printing workflows from FormIt and it would be good to see what users are attempting.
Hello again, Its really good customer service at Autodesk! And I am exciting being a part of this 3d revolution 🙂 Attached is the .axm-file as requested and some info from Meshmixer (I really dont like that automatic repair and what it does to my architectural shapes...). For your information, since you are interested in the workflow or interface for architecture modelling and 3d prints - I have also corresponded with Nathan Chandler (Fusion360, Inventor and .obj) and Tom Vollaro (Formit and Revit) on connected themes/issues. I could forward some emails to you on this. I am running a Macbook Pro with OS X 10.10.1 and Windows 7 (Parallels). I also have an IPad 2 and an IPhone 4s. Plan on printing these small houses in different metric scales like 1-500, 1-200 and 1-100 on my recently purchased Printrbot Simple Metal Black. Regards, Harald
Harald,
I took at look at your files. I do not think there is a great option to automatically fix the various water-tight errors. However, when I opened the OBJ file in Meshmixer it immediately highlighted the errors in blue. You can then use that as a guide and use the 3D sketching tool in FormIt to fix the errors. See video here
Hello, hello
Thanks for a good reply.
Probably the earliest housemodels are not as accurate as the last ones. Thanks also for the video, I will use this as a help when editing the model.
I believe the model will be watertight soon!
Thanks again! 🙂
Harald
Harald,
Hi! I am glad this helped. Do you mind if I use these images as part of a post on our blog about this topic?
Harald,
I know you've probably moved on past this problem, but I wanted to let you know that the FormIt development team is currently working on a feature to highlight watertight issues in your models, to allow cleaning them up. Expect to see it in our next release!
-Emerson, FormIt Developer
