Formit Import into Revit Not Working
I've tried on multiple files to import a Formit Sketch in Revit via the plug in tabs and nothing happens.  Differente Sketch files and different Revit Files.  Any ideas? See attached screencast.
josh.goldstein
Hi JNewberry,
Thanks for the screencast - very helpful.
We noticed your FormIt add-in for Revit has our old logo, and that tipped us off that you probably have an old version of the add-in installed.
Can you uninstall it and install the latest version for your version of Revit here: http://formit360.autodesk.com/page/download (scroll to the bottom).
We're working on an auto-updater or notification of update for the add-in, so this will be a bit more intuitive in the future.
Let us know if this resolves the issue.
Josh Goldstein
Senior Product Manager
This seems to have done it! I was still having issues with SKP models which were converted to AXM and then imported, but ungrouping it all seemed to resolve it.
Should have thought to check the version 😛
Thanks!
Josh.goldstein,
I am having the same issues with not being able to see any of my FormIt model when I imported it to Revit from FormIt.  Both FormIt Converter and Revit are 2016, my masses are checked on, and I used the link that you previously provided and I still cannot see anything show up.  On previous forums/blogs the tab to CONVERT FormIt to Revit was available in the directions, but mine says IMPORT FormIt to Revit.  Does that have anything to do with why I can't see anything?
f.muzard
I had the same problem and it came from loading a file with a path with accents (sorry I'm french 😉
Same problem too when trying to save a Formit file from Formit PRO on a file server : "error unable to save file".
I hope that Formit can be translated in French and have accent support !
smilksh
f.muzard,
Thank you for notifying us of the problem.  We hope to have better international support in a future release.
rmarkowitz
I am still having this issue...
I believe my Formit Converter is up to date (is there a way to check?). It seems to import very simple models ok, but ones with slightly more complex geometry do not appear in Revit; still sans error message.
Any additional insight would be much appreciated!
