FMDesktop (Read Only)
text in drawing legend
1 REPLY 1
789 Views, 1 Reply
I have a drawing that I created a hatching report. the legend is in the upper right corner and the text for each hatch pattern is squished to 2 lines.
Can I adjust how the text is displayed so that it is on one line? If so, how is this done?
thanks,
tim
1 REPLY 1
Tim -
Remember when working with the database - back up first and after. Compact
and Repair the DB after working in it. Any changes to Reports, Forms,
Queries, Macros are only seen on the systems that have that MDB file. Make a
copy of the report before any changes are made to roll back, and did I
mention to back up the MDB file.
For the general knowledge of the group, that report is the Space Assignment
by Cost Center report. Reports are formatted in MS-Access and found in the
Reports | Objects of the Facility Manager 7.mdb file. To change the fields
size, field, font, etc.... you would need to adjust the report using normal
MS-Access commands. In this report the legend is a separate sub-report.
If you have customized reports or any other parts of the system I recommend
that you document all changes and archive a copy of the DB off the system,
in a network, on a CD, thumb drive, etc... so if you have a system crash you
can copy your customizations back in.
smk
Stephen M Komisarek
wrote in message news:5478237@discussion.autodesk.com...
lines.
how is this done?
thanks,
tim
