FMDesktop (Read Only)
jar92380
389 Views, 1 Reply
Label Styles
Does anyone know how to get the Equipment Label to work? For instance where does the label pull the equipmnent information from?
Thanks in Advance
1 REPLY 1
mark.evans
in reply to: jar92380
Assuming you are in Facility Manager 7... The equipment label displays the current value for each equipment field that you request in the label setup. For example, if you select "Description", the current value stored in the Description field for each piece of equipment will be displayed over the equipment. You can edit these values either by selecting equipment graphically, or by scrolling through them with the equipment forms.
Or, your question may be how to get equipment in. Today, you can only create equipment in the drawing by using Facility Link.
Mark Evans
Senior Product Manager
AEC Division, Simulation Product Line
