FMDesktop
Active Member
jaynesworth
Message 11 of 13 (155 Views)
Re: Importing DWF
04-23-2007 09:18 AM in reply to: bobbyc42
Point of interest: I pulled up a Revit Systems Plus 2 file in Revit Building 9.1 and exported a DWF. That file imported into FMDesktop without a whimper. I don't know if I'll be able to do that after the 30-day evaluation period, though, or if any important information might not transfer from Systems Plus 2 to Building 9.1.
Active Member
jaynesworth
Message 12 of 13 (155 Views)
Re: Importing DWF
04-23-2007 04:33 PM in reply to: bobbyc42
There is an easy, no-cost way to get data from Revit Systems Plus 2 to FMDesktop 7.
1. Find a copy of Revit Building 9.1 (not 9.0). If you don't have the distribution disks, download a copy from http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9262404
I picked Revit Building 9.1 for Autodesk AutoCAD Revit Series—Building 9.1.
2. Install as Standalone Trial or Demo. The Trial give you a fully functional copy for 30 days. After 30 days, it reverts to Demo mode for legal, indefinite use.
3. Both modes allow you to retrieve files saved in Revit Building Systems 2 and print, plot, and export to DWF. Just follow the normal procedure to export DWFs from Building 9.1 to FMDesktop.
bobbyc42
Message 13 of 13 (155 Views)
Re: Importing DWF
08-22-2007 06:10 AM in reply to: bobbyc42
I have now successfully installed Hotfix 2 and that has taken care of the problem of importing 2008 drawings into FM Desktop. I tried the import process yesterday and it worked fine. Thanks.
Post to the Community
New Post
Need installation help?
