Are you asking if FMDesktop integrates (shares data or functionality) with Maximo? Or are you asking if they can run side-by-side using the same SQL Server 2000 instance?
There is no "out-of-the-box" integration between Maximo and FMDesktop.
The SQL Server editions of FMDesktop applications are tested on SQL Server 2000. There should be no issues with FMDesktop sharing a SQL Server 2000 instance if your IT staff can establish proper security and administration settings without conflict. However, our testing does not include running side-by-side with other applications.
Mark Evans
Mark Evans
Senior Product Manager
AEC Division, Simulation Product Line
Autodesk, Inc.
