Andido,
You are correct, the quality of some of the reports is pretty poor compared to the 6.5 quality. Labels are especially hard hit. In 6.5, the labels were generated in Facility Link (vector based drawing files). In 7.1, they are image files.
The best we've been able to do is go into a table called tbl_systemsettings. In that table, there is an output format and print quality. The best output format we've found is to use PNG. Irfanview is a free PNG viewer that does a really nice job ... search for it on download.com or tucows.
The best print quality setting that I've seen is to use 2.5 (if your system can do it). Those reports look pretty good on that output.
The tbl_systemsettings is in the PROGRAM .mdb file (Facility Manager 7.mdb in the program files directory). So, if you have multiple systems, you'll need to update that on each system.
Hope that helps,
Jon Luby
