FMDesktop (Read Only)
Facility Manager 6.5
6 REPLIES 6
vamsi.kakarla
595 Views, 6 Replies
Could someone plesae advice if there are any compaitbility issues with Facility Manager 6.5 on AutoCAD2008. One of my clients have been getting the error "wfrmview.whip1_onprogress Error#6 with message : overflow" after upgrading to AutoCAD2008 from AutoCAD2007.
6 REPLIES 6
in reply to: vamsi.kakarla
see post from mark evans 07/02/2007... thread title "FMD 6.5 compatible
with AutoCAD 2008"
> Yes, there is a problem installing Facility Link with AutoCAD 2008
and > AutoCAD Architecture 2008. We are building a patch for Facility Link
> that solves the problem. Monitor the FMDesktop support site to see it
> when it is available. I don't see a date yet from the development
team > so it is not imminent.
> Mark Evans
> Autodesk
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com
Don't forget to take the www.AUGI.com Salary Survey in October!
mark.evans
Facility Manager 7.1 and Facility Link 7.1 are tested and compatible with ACAD 2008 and the other 2008 products. The FMDesktop 7.1 products have been announced and should be at subscription customers very soon.
There will not be any patches to FMDesktop 6.5 products.
Mark Evans
Mark Evans
Senior Product Manager
AEC Division, Simulation Product Line
Mark,
~pause~ So, am I reading this as that the 7.0 products aren't
technically compatible with 2008 products?
Melanie Perry
> Mark Evans
> Autodesk
mark.evans
That's technically correct. There are some cases where Facility Link 7 will work correctly with some of the 2008 products, but there are other configurations that will not work. With regard to Facility Manager 7, DWF files created in the vertical 2008 products (ie, ACAD Architecture or the Revit products) will not be recognized by Facility Manager DWF Import.
The upgrade from 7 to 7.1 is painless.
Mark Evans
Mark Evans
mark.evans
And I also should have mentioned that in 7.1, the DWF Import command now recognizes equipment. You can selectively import equipment and related metadata from the design applications. I think this is relevant to some of the ideas you've had about tracking various pieces of equipment.
Mark Evans
Mark Evans
that doesn't really help me at all, and explains my dwf publishing
problems.
dagnabbit...
> Mark Evans
> Autodesk
