FMDesktop (Read Only)
error when publishing dwf
1 REPLY 1
4798 Views, 1 Reply
I'm trying to determine if this is a problem with AutoCAD Architecture,
or with FMDesktop.
Running ACA 08 SP1 with Facility Link 7.1 (win xp, and autocad
recommended standard pc specs, I don't recall the exact config)
When using aca File > Publish on a floor plan with mainly acad entities
and a few hundred 'spaces', I will crash out. send error report. rinse
and repeat.
when using the dwf publish on the fmd toolbar, I get the below error,
but, aca doesn't crash:
I'd appreciate any thoughts...
Thank you
error \/
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Data.ConstraintException: Failed to enable constraints. One or
more rows contain values violating non-null, unique, or foreign-key
constraints.
at System.Data.DataSet.FailedEnableConstraints()
at System.Data.DataSet.EnableConstraints()
at System.Data.DataSet.set_EnforceConstraints(Boolean value)
at System.Data.Common.DataAdapter.Fill(DataTable[] dataTables,
IDataReader dataReader, Int32 startRecord, Int32 maxRecords)
at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset,
DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String
srcTable, IDbCommand command, CommandBehavior behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables,
Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior
behavior)
at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable)
at
FmLink.Database.SharedDataSetTableAdapters.OleDb.FloorIdTableAdapter.Fill(FloorIdDataTable
dataTable)
at FmLink.Database.SharedDataSet.FillTables()
at FmLink.Database.Data.FillTables()
at FmLink.Application.CommandClass.Publish()
at AcMgCommandClass.InvokeWorker(AcMgCommandClass* , MethodInfo mi,
Object commandObject, Boolean bLispFunction)
at
AcMgCommandClass.InvokeWorkerWithExceptionFilter(AcMgCommandClass* ,
MethodInfo mi, Object commandObject, Boolean bLispFunction)
at AcMgPerDocumentCommandClass.Invoke(AcMgPerDocumentCommandClass* ,
gcroot<:REFLECTION::METHODINFO>* mi, Boolean bLispFunction)
at AcMgCommandClass.CommandThunk.Invoke(CommandThunk* )
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase:
file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.1.0.0
Win32 Version: 17.1.219.0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase:
file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
acmgd
Win32 Version: 17.1.51.0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/acmgd.DLL
AecSpaceOffsetRulesManager
Assembly Version: 5.5.256.0
Win32 Version: 5, 5, 256, 0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecSpaceOffsetRulesManager.DLL
AecSpaceOffsetStandardBasic
Win32 Version: 5.5.256.0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecSpaceOffsetStandardBasic.DLL
AecBaseMgd
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecBaseMgd.DLL
AecSpaceOffsetStandardBasic.resources
Assembly Version: 5.5.235.0
Win32 Version: 5, 5, 235, 0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardBasic.resources.DLL
AecArchMgd
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecArchMgd.DLL
System
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
AecSpaceOffsetStandardBOMA
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Space%20Calculation%20Standards/AecSpaceOffsetStandardBOMA.dll
AecSpaceOffsetStandardBOMA.resources
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardBOMA.resources.DLL
AecSpaceOffsetStandardDIN
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Space%20Calculation%20Standards/AecSpaceOffsetStandardDIN.dll
AecSpaceOffsetStandardDIN.resources
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardDIN.resources.DLL
AecSpaceOffsetStandardSIS
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Space%20Calculation%20Standards/AecSpaceOffsetStandardSIS.dll
AecSpaceOffsetStandardSIS.resources
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AecSpaceOffsetStandardSIS.resources.DLL
AecDtlDb
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecDtlDb.DLL
AecDtlDbUI
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecDtlDbUI.DLL
AecDtlDbLib
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AecDtlDbLib.DLL
FmLink
Assembly Version: 7.1.219.0
Win32 Version: 7.1.219.0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/FMDesktop/FmLink.dll
AecUtils
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/FMDesktop/AecUtils.DLL
System.Windows.Forms
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
FmLink.resources
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/FMDesktop/en-US/FmLink.resources.DLL
AcDashboard
Assembly Version: 0.0.0.0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcDashboard.arx
AcLayer
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcLayer.DLL
AcMgdShared
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcMgdShared.DLL
acmgdinternal
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/acmgdinternal.DLL
Accessibility
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcLayer.resources
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AcLayer.resources.DLL
AcInfoCenterConn
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AcInfoCenterConn.DLL
AdInfoCenter
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/AdInfoCenter.DLL
Autodesk.Interop.AcInetEngine
Assembly Version: 17.1.51.0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Autodesk.Interop.AcInetEngine.DLL
AdInfoCenter.resources
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/en-US/AdInfoCenter.resources.DLL
System.Xml
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
acgx8qaj
CodeBase:
Autodesk.Interop.WSCommCntr1
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Autodesk.Interop.WSCommCntr1.DLL
Autodesk.Interop.WebServices1
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/Autodesk.Interop.WebServices1.DLL
System.Web.Services
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
Microsoft.JScript
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.832
CodeBase:
file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
ygle1icj
CodeBase:
AecUtilsWrapper
Win32 Version: 7, 1, 219, 0
CodeBase:
file:///C:/Program%20Files/AutoCAD%20Architecture%202008/FMDesktop/AecUtilsWrapper.DLL
System.Data
CodeBase:
file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase:
file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase:
file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
1 REPLY 1
and for my next request... I'd like someone to come kick my *** for
being stupid, or clap me on the back for being such a genius... either
way, FSM knows I find the solution about 2 minutes after asking the
question...
SO, the answer is... technically, it's an ACA thing...
My default save is to r2004, as I've still got some users on 05.
I simply saved my plan as r2007 format, and it published with no errors.
it took about five minutes to complete the publishing, I'll assume it's
because of my 740 Space objects, though. 🙂
So... yeah... question and answer. Thank you for stopping by.
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com
> or with FMDesktop.
> and repeat.
> Thank you
> error \/
> constraints.
> behavior)
> at
> dataTable)
> at
> mscorlib
> CodeBase:
> acdbmgd
> CodeBase:
> msvcm80
> CodeBase:
> acmgd
> CodeBase:
> CodeBase:
> CodeBase:
> AecBaseMgd
> CodeBase:
> CodeBase:
> AecArchMgd
> CodeBase:
> System
> CodeBase:
> CodeBase:
> CodeBase:
> CodeBase:
> CodeBase:
> CodeBase:
> CodeBase:
> AecDtlDb
> CodeBase:
> AecDtlDbUI
> CodeBase:
> AecDtlDbLib
> CodeBase:
> FmLink
> CodeBase:
> AecUtils
> CodeBase:
> CodeBase:
> System.Drawing
> CodeBase:
> FmLink.resources
> CodeBase:
> AcDashboard
> CodeBase:
> AcLayer
> CodeBase:
> AcMgdShared
> CodeBase:
> acmgdinternal
> CodeBase:
> Accessibility
> CodeBase:
> AcLayer.resources
> CodeBase:
> AcInfoCenterConn
> CodeBase:
> AdInfoCenter
> CodeBase:
> CodeBase:
> CodeBase:
> System.Xml
> CodeBase:
> CodeBase:
> acgx8qaj
> CodeBase:
> CodeBase:
> CodeBase:
> System.Web.Services
> CodeBase:
> Microsoft.JScript
> CodeBase:
> ygle1icj
> CodeBase:
> AecUtilsWrapper
> CodeBase:
> System.Data
> CodeBase:
> System.Transactions
> CodeBase:
> CodeBase:
> enabled.
> For example:
