FMDesktop (Read Only)
Customizing the Title Block
2 REPLIES 2
bellj
451 Views, 2 Replies
How do I go about tweaking the dynamic plan view title block to replace the FM Desktop logo and name with our company's logo and name? We generate monthly reports for management and my boss wants the title block to match our current standards. We're currently using FMD 6.5, but are in the process of upgrading to 7.
2 REPLIES 2
bfahlin
in reply to: bellj
I would suggest looking at the reports in version 7 first before making any changes because the format has changed slightly. The graphic in the report will use the graphic you define on the organization form. However, if you need to make changes you can use MS Access to edit the Dynamic Plan View 1, 2 & 3 reports to suite your needs.
Hope this helps
bellj
in reply to: bellj
Thanks. We'll give it a try.
