FM (Read Only)
Map to MapGuide Coordinate Problem
1 REPLY 1
343 Views, 1 Reply
A problem that has always been there is working with or trying to avoid coordinate systems. I will get two drawings that overlay perfectly using X-refs but one will be way out of scale in MapGuide.
MapGuide tried to deal with this by using Arbritrary X-Y coords. FM is generally not concerned with Coord. sys., and usually will have none assigned in Map/LDD if they have either. I can change to a state-plane setting in Map but what about the person using ADT?
Why are these so out of whack with each other?
Input greatly appreciated.
1 REPLY 1
Just in case anybody cares, the solution is a simple one.
Make sure you assign units in the drawing:
Format > Units... > Drawing Units for DesignCenter Blocks.
Barry Kelly
GeoSpatial Web Services
