FM
*cafmboss
Post 11 of 16
Re: facility management / autocad help. ASAP
01-20-2003 12:22 AM in reply to: *Paddleford, Jace
Jace,
Off the shelf there isn't a solution. However, a solution could be
created with just a few hours of progamming effort using either
attributes that are a part of the workstation block or extended entity
data attached to the block.
Is there a source for the information, namely a listing (Excel?) of
names to desks? If so, then this could even be extracted into the
drawing (all part of the customization process).
We have done exactly what you described, but using ARCHIBUS. I'm
certain that this could probably be possible with some of the other
AutoCAD centric CAFM packages out there.
I'd be happy to work you through some of the steps here in this forum or
via email, so that you can see how to code it yourself.
Good luck!
Bob Visser
Jace Paddleford wrote:
> the firm i work for has been asked to do some facility management. what the
> client is wanting (they have autocad) is to be able to click on a
> workstation on the floor plan and it give them the information of that
> employee. i have no earthly idea how that is going to work. is there some
> autodesk software that is designed for this type of work? any help????
*Dirkasaurus
Post 12 of 16
01-21-2003 04:23 AM in reply to: *Paddleford, Jace
Jace,
If the firm has AutoCAD you should use that. Almost everything you want to
do can be accomplished with AutoCAD's database connectivity features
(specifically dbConnect) combined with a little of AutoCAD's Visual Basic
for Application programming to create the some SQL statements to call
recordsets from the database. I assume the reason you want to use .dwf's is
so that all can view these floor plans with IE, correct? It will get more
complex if you want the viewers of the .dwf to have the ability to modify
the data as is a graphical interface.
See the following thread for some example code related to this topic
although using MS Access:
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&group=autodesk.a
utocad.customization.vba
Another good source of information is Scott McFarlane's "AutoCAD database
connectivity" book which also comes with example code on a CD.
Dirk Weber
"Jace Paddleford" wrote in message
news:71AE9F63108EBA740959014D968F733E@in.WebX.maYIadrTaRb...
the
*Rylander, Joakim
Post 13 of 16
Re:
01-21-2003 09:37 PM in reply to: *Paddleford, Jace
With 2000 seats it's a big enough company to justify using MapGuide and the
ability for you to spread this application to many more users than you can
do with simple DWG files connected to a database in AutoCAD.
I'm sure there is more than one user for this system, and there is many
other potential users out there.
Just add the IT department, I'm sure they love to add the cabling and IT
infrastructure to it, so they quickly can find and locate any equipment,
2000 employeees must add up to much PCs, software licenses, cabling etc.
Let the IT department handle their own equipment, I'm sure your CAD manager
won't manage all the equipment and maintenance, so he is happy to give the
job to the department that needs it.
The HR department want another set of info for each employee, so there you
need a connection to another DB, how to manage that in AutoCAD? Btw, AutoCAD
cost a bomb to put where the users are, they are not experienced CAD
users...
With MapGuide you have a web page for login, and each user will only see
data that are valid for them, not anything else.
The IT dep. should not see the HR dep. data but both should see the internal
white pages/directory/location maps with names, photos and contacts for all
employees.
With MapGuide you get some samples exposing drawings over internet/intranet
in a webbrowser, with ability to edit and update the data with just the
browser and the plugin, no need for AutoCAD except for changing the
underlaying floorplan.
There is also some simple example online at:
http://usa.autodesk.com/adsk/index/0,,939407-123112,00.html
Check the link to Facility Management, simple but I'm sure it fit your bill,
and you will have full sourcecode, Javascript and ASP or ColdFusion.
Any webdeveloper can develop this demo further, and you just change the
drawings and add a tree-view for changing floorplans.
FM is not something for the CAD department, it's a useful tool for the whole
organisation.
Add ability to search for users, locate them, add direct email, and maybe
online chat and document management... it's just the start...
Good luck!
Best regards,
Jocke
"Dirkasaurus" wrote in message
news:smileyvery-happy:A7283C6C1FEE84CA5105060486A4623@in.WebX.maYIadrTaRb...
> Jace,
is
> Dirk Weber
> the
some
03-19-2003 08:38 AM in reply to: *Paddleford, Jace
Look at FM Desktop www.dtitech.com
the
*Ramm, Andy
Post 15 of 16
Re:
12-14-2003 06:51 AM in reply to: *Paddleford, Jace
You might take a look at this. We're still working on a demo script, so you
probably won't see everything it can do. What do you think.....?
http://mobile.autodesk.com/fm2002/
Andy
"Joakim Rylander" wrote in message
news:ED9260D4AF2BBE706CA290ED4195F880@in.WebX.maYIadrTaRb...
> Hi,
the
manager
AutoCAD
> users...
internal
all
> employees.
internet/intranet
bill,
whole
> organisation.
> Good luck!
> Best regards,
> Jocke
> > Jace,
to
Basic
> is
more
modify
database
> > Dirk Weber
what
> > the
> some
help????
Member
0 Kudos
Post 16 of 16
Re:
Andy,
It looks like a good start for a Space Management app (portal?), but FM is a lot more. I see the visibility for assets to be hooked in, but then your mech and electric rooms are specifically not mapped. Although this may be a difference between what certain FM offices consider "assets."
IMO, the accessibility to info concerning maintenance work orders/real property/energy mgmt/etc is what "transforms" a SM app into a full FM app.
Respectfully,
Joe Tilman
