FM (Read Only)
facility management / autocad help. ASAP
15 REPLIES 15
Message 1 of 16
1013 Views, 15 Replies
the firm i work for has been asked to do some facility management. what the
client is wanting (they have autocad) is to be able to click on a
workstation on the floor plan and it give them the information of that
employee. i have no earthly idea how that is going to work. is there some
autodesk software that is designed for this type of work? any help????
15 REPLIES 15
Message 2 of 16
Jace -
Take a look at the discussion group for Facilities Management and
ask for help there.
FACILITIES MANAGEMENT
http://discussion.autodesk.com/WebX?14@@.f12d9f4 or
news://discussion.autodesk.com/autodesk.fm
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
Jace Paddleford wrote:
> the firm i work for has been asked to do some facility management. (snip)
Message 3 of 16
You could make each workstation a block with preset and hidden atributes.
Then when you type attedit it brings up all the info you gave it.
Then if someone moves or quits you can change the info easily.
"Jace Paddleford" wrote in message
news:71AE9F63108EBA740959014D968F733E@in.WebX.maYIadrTaRb...
the
Message 4 of 16
thanks Anne, i hadnt noticed that group.
Dann - ive thought of that, but we are talking around 600 employees at this
location, and i have a sneaking suspicion that this will grow to the entire
company 2000+ employees. it could / would work, but was wondering what
options there are out there.
thanks for the suggestion
"Dann Brower" wrote in message
news:092EE95362C54BE7C7299B68DFF4E67D@in.WebX.maYIadrTaRb...
> the
some
Message 5 of 16
This probably won't help you, but with ADT you can do exactly what you what you want.
Message 6 of 16
you could look into arcview as well
Dave C. Johnson
WWC Engineering
Sheridan WY.
Windows 2k2
Acad Map 5
Survcadd XML
remove OUT to reply
Message 7 of 16
longleyje
If you don't have ADT and you don't have Arcview and you are limited to what you have, is this not, then, an appropriate place to use AutoCAD's database connectivity?.
Beyond that I would be over my head as to the specific how-tos. A2K shipped with db_sample.dwg and db_sample.mdb (Microsoft Access database) that did/does do this sort of application. A starting point at any rate
JimL
Message 8 of 16
an update - just meet w/ the client. they are wanting to somehow link a
drawing to their sql database. this way they can locate employees by floor
/ department, either by the database or floor plan. i think the floor plan
would be a dwf format rather than a dwg.
im not sure what im getting myself into.................
the
Message 9 of 16
dlacomb
If they have AutoCAD, you may not need much else. You could create a block of the workstation and assign attributes (text information) to each with whatever information (fields) you want to be displayed. AutoCAD 2002 also allows an easy way of extracting the information to a spreadsheet. Very simple and straight-forward. Hope this helps.
Dave LaComb, AIA
Message 10 of 16
Jace hi,
The program that should be able to do what you need is Autodesk Map.
Map can help you connect different AutoCAD objects to more Data (In or out
of the file).
It can also help query data based on different criteria: Names, Location and
much more.
Map 5 or 6 can enable you to migrate all your drawing data (When too large)
to Oracle Spatial Database.
You should look into it.
Arad
news:B95917FCD323F06B06CCC3AB75ED0EA0@in.WebX.maYIadrTaRb...
floor
plan
> the
some
Message 11 of 16
Jace,
Off the shelf there isn't a solution. However, a solution could be
created with just a few hours of progamming effort using either
attributes that are a part of the workstation block or extended entity
data attached to the block.
Is there a source for the information, namely a listing (Excel?) of
names to desks? If so, then this could even be extracted into the
drawing (all part of the customization process).
We have done exactly what you described, but using ARCHIBUS. I'm
certain that this could probably be possible with some of the other
AutoCAD centric CAFM packages out there.
I'd be happy to work you through some of the steps here in this forum or
via email, so that you can see how to code it yourself.
Good luck!
Bob Visser
Message 12 of 16
Jace,
If the firm has AutoCAD you should use that. Almost everything you want to
do can be accomplished with AutoCAD's database connectivity features
(specifically dbConnect) combined with a little of AutoCAD's Visual Basic
for Application programming to create the some SQL statements to call
recordsets from the database. I assume the reason you want to use .dwf's is
so that all can view these floor plans with IE, correct? It will get more
complex if you want the viewers of the .dwf to have the ability to modify
the data as is a graphical interface.
See the following thread for some example code related to this topic
although using MS Access:
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=UTF-8&group=autodesk.a
utocad.customization.vba
Another good source of information is Scott McFarlane's "AutoCAD database
connectivity" book which also comes with example code on a CD.
Dirk Weber
the
Message 13 of 16
With 2000 seats it's a big enough company to justify using MapGuide and the
ability for you to spread this application to many more users than you can
do with simple DWG files connected to a database in AutoCAD.
I'm sure there is more than one user for this system, and there is many
other potential users out there.
Just add the IT department, I'm sure they love to add the cabling and IT
infrastructure to it, so they quickly can find and locate any equipment,
2000 employeees must add up to much PCs, software licenses, cabling etc.
Let the IT department handle their own equipment, I'm sure your CAD manager
won't manage all the equipment and maintenance, so he is happy to give the
job to the department that needs it.
The HR department want another set of info for each employee, so there you
need a connection to another DB, how to manage that in AutoCAD? Btw, AutoCAD
cost a bomb to put where the users are, they are not experienced CAD
users...
With MapGuide you have a web page for login, and each user will only see
data that are valid for them, not anything else.
The IT dep. should not see the HR dep. data but both should see the internal
white pages/directory/location maps with names, photos and contacts for all
employees.
With MapGuide you get some samples exposing drawings over internet/intranet
in a webbrowser, with ability to edit and update the data with just the
browser and the plugin, no need for AutoCAD except for changing the
underlaying floorplan.
There is also some simple example online at:
http://usa.autodesk.com/adsk/index/0,,939407-123112,00.html
Check the link to Facility Management, simple but I'm sure it fit your bill,
and you will have full sourcecode, Javascript and ASP or ColdFusion.
Any webdeveloper can develop this demo further, and you just change the
drawings and add a tree-view for changing floorplans.
FM is not something for the CAD department, it's a useful tool for the whole
organisation.
Add ability to search for users, locate them, add direct email, and maybe
online chat and document management... it's just the start...
Good luck!
Best regards,
Jocke
"Dirkasaurus" wrote in message
news:DA7283C6C1FEE84CA5105060486A4623@in.WebX.maYIadrTaRb...
> Jace,
is
> Dirk Weber
> the
some
Message 14 of 16
Look at FM Desktop www.dtitech.com
the
Message 15 of 16
You might take a look at this. We're still working on a demo script, so you
probably won't see everything it can do. What do you think.....?
http://mobile.autodesk.com/fm2002/
Andy
"Joakim Rylander" wrote in message
news:ED9260D4AF2BBE706CA290ED4195F880@in.WebX.maYIadrTaRb...
> Hi,
the
manager
AutoCAD
> users...
internal
all
> employees.
internet/intranet
bill,
whole
> organisation.
> Good luck!
> Best regards,
> Jocke
> > Jace,
to
Basic
> is
more
modify
database
> > Dirk Weber
what
> > the
> some
help????
Message 16 of 16
mr_tilman
Andy,
It looks like a good start for a Space Management app (portal?), but FM is a lot more. I see the visibility for assets to be hooked in, but then your mech and electric rooms are specifically not mapped. Although this may be a difference between what certain FM offices consider "assets."
IMO, the accessibility to info concerning maintenance work orders/real property/energy mgmt/etc is what "transforms" a SM app into a full FM app.
Respectfully,
Joe Tilman
