FM
New Member
BorlCand
Message 1 of 3 (1,831 Views)
3ds Max Design 2011 - Approximately 3% at the end of damaged
1831 Views, 2 Replies
04-01-2011 06:21 AM
                        Hello!
   Downloaded Autodesk_3ds_Max_Design_2011_English_Win_32_Trial.exe, and a computer for about 4.3 minutes before the shut down ... Included again download - delighted! Download ...
    Then open, extract, and approximately 97 percent does not unpack the files (CRC does not match).
    I ask those who have unpacked the archive Autodesk_3ds_Max_Design_2011_English_Win_32_Trial.exe deflate the necessary files, and archive in the archiver. Tar.gz or other strong, so that the file was small.Total affected 50 files.
   List of files relative to the root folder is attached:
Spoiler
support\ADSKMaterials\CM\Protei~1.cab
x86\max\TranslatorsCommon.cab
x86\max\TranslatorsCommonLoc.cab
NETVerifier\Netfx20TestApplication.exe.config
CER\client.css
SetupRes\max.ico
max.ico
Microsoft.VC90.CRT.manifest
Microsoft.VC90.MFC.manifest
ProdDep_UserDep.mc3
ProdDep_UserInd.mc3
ProdInd_UserDep.mc3
ProdInd_UserInd.mc3
mapfile.mlm
x86\max\3dsMaxDesign2011_32-bit.msi
support\backburner\2011\backburner.msi
support\backburner\IPv6\backburner\backburner.msi
support\backburner\backburner.msi
SetupRes\eval.msi
support\msxml\msxml6.msi
support\ADSKMaterials\CM\ProteinMaterials.msi
support\ADSKMaterials\CM\ProteinMaterialsSP1.msp
SetupRes\deploy.mst
SetupRes\gpo.mst
msi\Windows6.0-KB942288-v2-ia64.msu
msi\Windows6.0-KB942288-v2-x64.msu
msi\Windows6.0-KB942288-v2-x86.msu
support\backburner\IPv6\backburner\Backburner_2008 2_(IPv6Only)_Readme.pdf
en-US\Docs\Install_3ds_Max.pdf
en-US\Docs\Licensing_3ds_Max.pdf
en-US\Docs\Samlite_ug.pdf
x86\max\3dsMaxDesignConfig.pit
x86\max\UPI\upiconfig.xml
upiconfig.xml
Many thanks in advance only! Do not want to re-download ...
______________
Regards, Andrew.
New Member
Celtemor
Message 2 of 3 (1,657 Views)
Re: 3ds Max Design 2011 - Approximately 3% at the end of damaged
11-16-2011 11:28 AM in reply to: BorlCand
Hey, I know it's been a while since you posted this, but I'm still recieving the same problem, and do not have an answer. Someone please help...It's getting anoying downloading the same files over and over.:smileytongue:
Distinguished Contributor
Wanderer-MOTD
Message 3 of 3 (1,613 Views)
01-16-2012 07:51 AM in reply to: Celtemor
No one will know that here.
You'll need to go to:
http://forums.augi.com/forumdisplay.php?f=300
or
http://area.autodesk.com/forum/autodesk-3ds-max/
Melanie Perry
***not all those who wander are lost***
http://AUGI.com/Surveys
http://MistressOfTheDorkness.blogspot.com
My defunct profiles:
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/651859
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/644095
