FM (Read Only)
3ds Max 2012 Stuck geometry coordinates
1 REPLY 1
tina1971
1795 Views, 1 Reply
I am having an issue .....When i create geometry it appears that the geometry is locked at x y and z coordinates and i am unable to move the geometry to any other coordinates .....I have checked everything to see what could be locked and have come up empty .....If anyone has a suggestion it would be greatly appreciated!
Thank you
T
1 REPLY 1
No one will know that here.
You'll need to go to:
http://forums.augi.com/forumdisplay.php?f=300
or
http://area.autodesk.com/forum/autodesk-3ds-max/
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
