It would be particularly useful if in using Flow Design with in Inventor Pro, that the net forces be available for an object. For example, In stress analysis in Inventor, you can probe for the value of stress at different locations. I realize that a net force on an object is the integral of the pressure distribution over an area. Short of getting a net force on an object, being able to probe for different pressures over the area, and then do the integration manually.
