Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
tunnel size voxel size pressure legend colors
1 REPLY 1
683 Views, 1 Reply
It would be absolutely great if we could set the tunnel size, even better if we could set the voxel size as well so we can make comparisons between simulations, otherwise the work is only very qualitative and no quantitative conclusions can be made. Add to this that if the pressure map colors represented the same pressure (or velocity) between simulations it would be absolutely awesome. I know all these features could add to the cost of the program but it could be worth. Cost wise, there is nothing in between Flow Design and Simulation, so most amateurs or self entreprenours cannot afford Simulation but maybe they could afford software with few more features than Flow Design even if it is a little more expensive. But anyways thank you very much for this product (Flow Design) as it still works for an initial qualitative assessment.
1 REPLY 1
Royce_adsk
Hello Radon,
There are all reasonable suggestions and I also think they would be good to add to the software.  The best place to make suggestions is the Idea's Station: http://forums.autodesk.com/t5/flow-design-ideastation/idb-p/idea10
If you could add each unique ideas as a seperate post that will allow everyone to vote on each idea which allows our product manager to provide more weight to adding various features to the software.
Best regards,
Royce.Abel
Technical Support Manager
