Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Set range for results
1 REPLY 1
stephanie.egger
517 Views, 1 Reply
Is there a way to set the output range for the results? For example, I'd love to be able to define the range for my velocity results so I can hone in on some lower velocity areas that, given the wide preset range, just appear as the same color gradient. I believe this was enabled in the Vasari Wind Tunnel.
Stephanie
Stephanie Egger
Evangelist, Building Performance Analysis
blogs.autodesk.com/insight360
1 REPLY 1
Nevermind...found my answer in the How to get a consistent color reading at legends? thread!
Stephanie Egger
