Is there a way to set the output range for the results? For example, I'd love to be able to define the range for my velocity results so I can hone in on some lower velocity areas that, given the wide preset range, just appear as the same color gradient. I believe this was enabled in the Vasari Wind Tunnel.
Stephanie
Solved by stephanie.egger. Go to Solution.
Nevermind...found my answer in the How to get a consistent color reading at legends? thread!
