I am using Flow Design as a stand-alone application.
Is there a way to set a realistic wind distribution (power-law or Log-law) for the inlet velocity?
Mafav
Solved by hartogj. Go to Solution.
This capability is only within the Revit plugin for Flow Design. It's not currently in the standalone version of Flow Design.
Another option (if you are a student or otherwise have access to it) is Simulation CFD. This package allows you to specify a variable inlet velocity profile along with many other details.
Jon
