Running on Windows7.
Have tried to open .obj/.stl files and keeps opening the sphere everytime. In the file types I don't see .wire option?
Solved by ryan.arnaudin. Go to Solution.
Would it be possible for you to send me the models? You can private message them to me if they are small enough.
Managed to import model. Had to select 'tessellate' in the save dialogue box for .obj files in Alias!
Still disappointed that I don't see the .wire format -qv attached screenshot?!!
Did you uncheck the Design Link option during installation? Leaving this checked will enable many additional file formats to be read by Flow Design.
I am having the same "ball" issues with every file format from Inventor 2015 - extruded ipt, aim, dwg and with any jpg images as well.
Having the same issues as well. Tried using Solid Works 2014 with .sldprt and Autodesk Inventor 2013 with .ipt.
