Solved by hartogj. Go to Solution.
The pressures typically seen on the face of a building will be only a tiny fraction of an MPa which is why you see 0.00 being reported.
If you change pressure units to Pa, you should see correct numerical results for the legend and plots. To do this, go to the "Manage" Ribbon tab, then choose "Project Units", then choose discipline structure and change the units for stress to Pa.
Jon
