Hi everyone,
The flow design plug-in for inventor is not available within Inventor 2015. is anyone experiencing the same issue?
Thanks.
Hi
There are a few things to check on that should help us sort this out:
1) Are you running a 64 bit version of Inventor?
2) Did you install Flow Design after installing Inventor?
3) Simple one, but are you looking for Flow Design on the "Environment" tab within Inventor?
4) Inventor 2015 support was added to Flow Design in March of this year. Can you let us know which build of Flow Design you installed? (open the standalone version and check "About)
Jon
Thanks for the update.
The build date indicates that you have an older release from January 2014, before Inventor version 2015 was available. Can you log into either the accounts portal or, if a student, the edu community and download the latest build?
Jon
I verified that the "Browser Download" option installs the latest build. The file name includes "R1" in the title which is an indicator that it is an update:
Flow_Design_2014_English_WIN_64bit_R1_dlm.sfx.exe
Can you please download using the "Browser Download" option if you haven't already? In the meantime we will look into the other methods to make sure they are providing the latest also.
Jon
