Hi everybody,
I would like to start some very basic stuff to learn how to handle with Flow Design. So I created a very simple 3D model in Inventor 2015 and saved it as an ipt-file.
When I import now this ipt-file, all the time, there is just a grey sphere shown. It doesn't matter which 3d model I've chosen. When I choose a "demonstration model" it works.
Do you have an idea, what I'm doing wrong?!
Thanks a lot for your help!
br, Tobias
Solved by Hagel123. Go to Solution.
Hi Tobias,
This suggests a geometry problem. Is the model overly complex and what happens if you bring through just half of it? (or the opposite half).
Are you able to share the ipt?
Kind regards,
Jon
I'm sorry, but it seems, I'm not able to upload the file. Nothing happens, when I click "Add attachment" 😞
Okay, with IE it works, with Firefox not.... anyway
Maybe this problem could be solved by exporting it as a .lst file.
- if you can transport your object to AutoCAD then you should open the file --> select the objects you want to test in the simulator --> export these object by clicking the AutoCAD'home' button --> choose other files --> select .slt and save it.
If I am correct this file can be opened in the simulator.
Hmm, two years later and this issue still exists. Exporting from Inventor as an STL and importing the STL into Flow Design still works, though. 🙂
I have the same problem just that I import the model as a .dwg file (3D). I tried to convert it in a .dwf file, but it doesn't even appear in the list when I want to import it in the program. I'm working in etabs2016 and I don't have other possibilities to export my model. Could you help me solve this inconvenience please?
