Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Flow Design for Revit - Only one document may be opened ERROR
3 REPLIES 3
530 Views, 3 Replies
I'm getting the following error when I start Flow Design in Revit 2014. "Only one document may be opened when Flow Design is running" Please help!
Tags (1)
3 REPLIES 3
mayur_dhumal
Yes this is the correct behavior, at a time you can start ONLY one session of Flow Design as a plug-in.
Mayur
in reply to: mayur_dhumal
Mayur
Thank you for your response but can you please elaborate.  I don't know what i'm doing to make the software not start. I only have one session of flow design. What do you mean by ONLY one session of Flow Design as a plug-in. Thank you very much!
hartogj
It sounds like you are doing everything correctly.
Can you start Flow Design on any model in Revit? Or is it just this one that is problematic? If so, please share it and let us know which version of Revit you are using so we can see if we can figure out what is going on.
Also, did you ever run Flow Design successfully before? I am wondering if something may be running in the background from a prior session in which case a reboot may be helpful if you haven't done that already.
Jon
Jon den Hartog
Product Manager
