Hi everyone,
Im trying to load a reasonably large assembly (5000 total parts, 900 unique). IAfter about 6 minutes I will return to the window and find a simple sphere being analysed in the airflow, even though it has the file name of the assembly I intended to load, displayed. I can load smaller assemblies without trouble. Any explanation?
Solved by S_May. Go to Solution.
try to export your model in 3ds format, if you select other cad types such as dwg, flow design just identifies a sphere...
Hi @Anonymous,
Please import your model experimentally in the extension dwg.
greetings
S_May
@Anonymous wrote:try to export your model in 3ds format, if you select other cad types such server info minecraft, flow design just identifies a sphere...
i have apply this guidance on my 3d format and it works.
