Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Can't import dwg
5 REPLIES 5
rafalg18
3257 Views, 5 Replies
Can't import dwg
I have tried import  dwg file to Flow Design then keeps opening sphere everytime.
I work on Windows 7 (64 bit)
What should I do??
Attached DWG MODEL.
5 REPLIES 5
Royce_adsk
in reply to: rafalg18
I used Inventor Fusion to read in the DWG file and converted it to a STEP file format and that allowed it to work.
Royce.Abel
Technical Support Manager
rafalg18
in reply to: Royce_adsk
Thanks for your help but I don't use  Inventor Fusion. Is possible to make the conversion in another program ( program used in civil engineering) or
direct import dwg ( from AutoCad to Flow Design)
hartogj
Hi
Thanks for letting us know you are seeing this.
The development team has tested this and observed similar behavior on some files generated in AutoCAD 2010 and later. The issue has been logged.
For now, as a workaround I would recommend outputting an STL straight from AutoCAD, ie. File>Export>Other Formats>Lithography (STL). There are lots of ways you could do this but this is likely the fastest.
Jon
Jon den Hartog
Product Manager
badaldutt09
Hi
I had a similar problem  so i Export my file to FBX  format and it worked.
Try it out.
Flash08
in reply to: hartogj
i am using inventor for 3d modelling and when iam trying to open .ipt file in flow design a sphere shows up can anyone solve my problem...?
