Hello
My name is Anastasiia and I'm a student of St.-Petersburg Polytechnical University.
I'm writting an article about wind loads on high-rise buildins. And if it's possible I would like to know what hypothesis and equations of math, physics, dynamics and ets. are used in the calculations in Flow Design? Because I am doing a comparative analysis of calculation in your programme and in according to existing russian construction standards and I need to know it
I'll be glad if you can answer me
Solved by hartogj. Go to Solution.
Hello
Flow Design runs calculations based on the Navier Stokes equations much like a traditional CFD application. The model is broken down into a series of elements (ie. "voxels") and solved using a Finite Volume Method aproach. Turbulence is accounted for using an LES turbulence model.
Jon
