Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Account Doesn't Work
3 REPLIES 3
condormeister
681 Views, 3 Replies
Hi there!
I downloaded Flow Design and installed it as student... Receive the confirmation email with product key and serial number! When I run Flow Design (Stand Alone mode) the next message appears "Your Autodesk account not entitled for Flow Design".
I don`t know what's wrong, the program or my account?
Sincerly, Daniel
"And On That Bombshell..."
3 REPLIES 3
LUROLAHU
in reply to: condormeister
Hello!
I have the exact same issue, i.e. EDU account, Flow Design Stand Alone, when starting the messages "Account not Authorized" and "Your Autodesk Account is not entitled for Flow Design." appear.
Here are two other threads describing the issue:
http://forums.autodesk.com/t5/flow-design-general-discussion/account-not-entitled-for-flow-design/td...
http://forums.autodesk.com/t5/flow-design-general-discussion/account-not-authorized-for-flow-design/...
But I can't find a solution.
Do I have to enable Flow Design in my account and if so, how to do it?
Best Regards,
Lukas
Anupama.rana
in reply to: LUROLAHU
I am having same problem. Any solution to fix it yet?
Regards
Anupama
hartogj
in reply to: Anupama.rana
Hi
Flow Design uses Autodesk's Single Sign On for login. In some cases we have seen authorization being blocked due to firewall restrictions. This article presents some things you can do to troubleshoot the issue:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Autodes...
It's not a certainty this is what is causing your issue but this would be a good first step for troubleshooting.
Jon
Jon den Hartog
Product Manager
