Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Opening Flow Design After Installation
1 REPLY 1
matthewberger94
617 Views, 1 Reply
I just got done installing Flow Design and tried opening the application and all that comes up is the loading screen. There is no loading status bar or any indication of what is happening. Anyone else had this problem?
1 REPLY 1
hartogj
in reply to: matthewberger94
If you are starting the standalone version of Flow Design and it is not appearing on screen, I'd first check the graphics card support. Do you know if your driver supports OpenGL 3.0 (or higher)?
Beyond that, be sure you are also on a supported OS and installed with admin rights.
Jon den Hartog
Product Manager
