Flame Forum
Welcome to Autodesk’s Flame Family (Flame, Flare, Flame Assist, Lustre) Forums. Share your knowledge, ask questions, and explore popular Flame topics.
does flame 2017.1.1 surport 1920*1080 screen?
5 REPLIES 5
494 Views, 5 Replies
thanks,i want learning it on hp 8770w
5 REPLIES 5
jaseo
The minimum system requirements do state 1920x1200 as being the minimum spec.
https://knowledge.autodesk.com/support/flame-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
However, 1920x1080 should work with minor UI issues (having not been designed for this resolution) which would be fine if you are just learning.
I assume you would be using the linux version. Fortunately, there is already a xorg.conf server layout option for 1920x1080.
# Screen 0 "Screen Default 1920x1080 EDID" 0 0
cheers
in reply to: jaseo
thank you jaseo,i find the intuos cursor is offset with 1920*1080 screen .mouse cursor is ok,and if mirror a 1920*1200 monitor as master screen intuos cursor is ok too,how to fix it?can you help me?thanks....
yann.laforest
Did you try to reset the cursor pointer and adjust the tablet margins in Preferences / Input Devices?
Please let us know,
Yann
Yann Laforest
Program Manager Data Analytics - Autodesk EMS
10 rue Duke Street
Montréal (Québec) Canada H3C 2L7
in reply to: yann.laforest
yes i did,but it`s still,with the flame2017.1.1 open,if let intuos pull out than insert than pull out than insert...it will be fine,and flame2016 is ok,thank you again
mabe these message is helpful in flame start windows:
POINTER : Initialising.
Executing command: /bin/sh /usr/bin/xsetwacom --version > /tmp/dlwacomr8TufK
Executing command: /bin/sh /usr/bin/xsetwacom --get "Wacom Intuos Pro M Pen stylus" twinview > /tmp/dlwacomy33XLe
Unknown parameter name 'twinview'.
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen stylus" ResetArea
Executing command: /bin/sh /usr/bin/xsetwacom --get "Wacom Intuos Pro M Pen stylus" Area > /tmp/dlwacomH4OojJ
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" RelWheelUp 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" RelWheelDown 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" AbsWheelUp 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" AbsWheelDown 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" AbsWheel2Up 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" AbsWheel2Down 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" StripLeftUp 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" StripLeftDown 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" StripRightUp 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" StripRightDown 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 1 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 2 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 3 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 4 0
Unsupported offset into 'Wacom Button Actions' property.
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 5 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 6 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 7 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 8 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 9 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 10 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 11 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 12 0
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen pad" Button 13 0
Executing command: /bin/sh /usr/bin/xsetwacom --get "Wacom Intuos Pro M Pen stylus" twinview > /tmp/dlwacomAX8G0d
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen stylus" Area 0 0 44704 27940
Executing command: /bin/sh /usr/bin/xsetwacom --get "Wacom Intuos Pro M Pen stylus" twinview > /tmp/dlwacom1PrLII
Executing command: /bin/sh /usr/bin/xsetwacom --set "Wacom Intuos Pro M Pen stylus" Area 2235 1397 42469 26543
POINTER : Initialising Wacom UD.
Executing command: /bin/sh /usr/bin/xsetwacom --get "Wacom Intuos Pro M Pen stylus" twinview > /tmp/dlwacomSz5Frd
Executing command: /bin/sh /usr/bin/xsetwacom --get "Wacom Intuos Pro M Pen stylus" twinview > /tmp/dlwacomBmBpbI
