Hi Fred,
Yes exactly, I am looking to cycle through options. So, if you take Blend&Comp it has five possible inputs. If you use the FCP shortcuts then Alt+Shift cycles through them each time you press shift (keep Alt down and click on Shift to cycle the options). With Flame however it just brings out the next available one and doesn't cycle each time you press Shift.
Cheers
Tony
HP Z840, 80GB Ram, Quadro M6000x24GB
