Solved by ProFORCEflorida. Go to Solution.
The only way I have done this is to snap your own geometry on the model and use the dimension tools in your geometry bar. You may have to put a vertical or horizontal line in there in addition to the one you placed on the angled surface to use this dimensional tool. Also I think you have to make sure they are on the same plane to analyse it correctly. Hope this helps!
This is way to find angles directly from a model.
Go to this FeatureCAM menu:
Construct>Curve>From Surface>Surface Projection
- now click on "wall angle" and select two points along the angle (from the model).
- once it shows you the angle then you can cancel out
Hope this helps!
