FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
URGENT: SDK failing to see UV coordinates
2 REPLIES 2
471 Views, 2 Replies
Please see attached .fbx
The artist added UV islands, and I can see them if I open the .fbx in 3D Coat
I need to convert the fbx into a proprietary format, and I use the FBX SDK for that.
However, when I get
  FbxGeometryElementUV* leUV = aMesh->GetElementUV(0);
leUV->GetMappingMode()
is
FbxGeometryElement::eByPolygonVertex:
but
aMesh->GetTextureUVIndex(i, j);
returns -1 for all vertices.
I can see that if I use ImportScene (from the SDK):
    Polygons
        Polygon 0
            Coordinates: -8187.017578, 9150.000000, -4962.866211
            Texture UV: 0.000000, 0.000000
            Normal: 0.000000, -1.000000, -0.000000
            Coordinates: -8859.222656, 9150.000000, -3890.286133
            Coordinates: -9494.500977, 9150.000000, -5544.650391
And the same for all polygons.
ANd there is nothing else in the output from ImportScene that shows the UV map.
How can I get to it?
TIA
Tags (1)
2 REPLIES 2
samsonite151
Polygons can have more than one UV layer.  Your UVs are on the 2nd UV layer, not the first one.
The first layer is all zero.
in reply to: samsonite151
Ah... OK
I'll look into that.
Thank you
