I'm trying to generate a bunch of boxes into an FBX file using the SDK. Each face of the boxes can have a different tiled texture and a different translation or offset coordinate from the default origin. I've figured out how to tile the textures using FbxGeometryElementUV and FBXVector2's but I'm having trouble seeing how the position offset can be applied to the faces of the cube.
thanks.
My current code. The top/bottom of the boxes are not tiled like the side walls.
// Create UV for Diffuse channel.
FbxGeometryElementUV* lUVDiffuseElement = lMesh->CreateElementUV("DiffuseUV");
FBX_ASSERT(lUVDiffuseElement != NULL);
lUVDiffuseElement->SetMappingMode(FbxGeometryElement::eByPolygonVertex);
lUVDiffuseElement->SetReferenceMode(FbxGeometryElement::eIndexToDirect);
//Wall vectors
FbxVector2 lVectors0(0, 0);
FbxVector2 lVectors1(1, 0);
FbxVector2 lVectors2(1, 4);
FbxVector2 lVectors3(0, 4);
FbxGeometryElementUV* lUVDiffuseElement = lMesh->CreateElementUV("DiffuseUV"); FBX_ASSERT(lUVDiffuseElement != NULL); lUVDiffuseElement->SetMappingMode(FbxGeometryElement::eByPolygonVertex); lUVDiffuseElement->SetReferenceMode(FbxGeometryElement::eIndexToDirect); //Wall vectors FbxVector2 lVectors0(0, 0); FbxVector2 lVectors1(1, 0); FbxVector2 lVectors2(1, 4); FbxVector2 lVectors3(0, 4); //top/bottom vectors FbxVector2 lVectors4(0, 0); FbxVector2 lVectors5(1, 0); FbxVector2 lVectors6(1, 1); FbxVector2 lVectors7(0, 1); lUVDiffuseElement->GetDirectArray().Add(lVectors0); lUVDiffuseElement->GetDirectArray().Add(lVectors1); lUVDiffuseElement->GetDirectArray().Add(lVectors2); lUVDiffuseElement->GetDirectArray().Add(lVectors3); //Vectors for top and bottom faces lUVDiffuseElement->GetDirectArray().Add(lVectors4); lUVDiffuseElement->GetDirectArray().Add(lVectors5); lUVDiffuseElement->GetDirectArray().Add(lVectors6); lUVDiffuseElement->GetDirectArray().Add(lVectors7); //FbxGeometryElementUV* lUVElement = lMesh->GetElementUV(0); //lUVElement-> //Now we have set the UVs as eIndexToDirect reference and in eByPolygonVertex mapping mode //we must update the size of the index array. lUVDiffuseElement->GetIndexArray().SetCount(24); // Create polygons. Assign texture and texture UV indices. for (i = 0; i < 6; i++) { // all faces of the cube have the same texture lMesh->BeginPolygon(-1, -1, -1, false); if ((i == 0) || (i==2))//Top and bottom { for (j = 4; j < 8; j++) { // Control point index lMesh->AddPolygon(lPolygonVertices[i * 4 + (j-4)]); // update the index array of the UVs that map the texture to the face lUVDiffuseElement->GetIndexArray().SetAt(i * 4 + (j-4), j); } } else {//east,west,north,south for (j = 0; j < 4; j++) { // Control point index lMesh->AddPolygon(lPolygonVertices[i * 4 + j]); // update the index array of the UVs that map the texture to the face lUVDiffuseElement->GetIndexArray().SetAt(i * 4 + j, j); } } lMesh->EndPolygon(); }
