I am using FBX as the default animated 3d model format in my engine. My artists are currently using Maya 2014 and Motionbuilder 2014 to create the model assets. I am currently using FBX2015.1 to load FBX model files. The model geometry, texture mapping, and rigging is created in Maya. Once we figured out that Maya can't create more than one animation take (stack), we began using Motionbuilder to create them. The problem I am having is that once the models with the extra animation takes exported from Motionbuilder is loaded via the FB SDK, any LOD group information is missing. We need those LOD group nodes and the meshes defined below them in order to separately render lower detail meshes at further camera distance. Is the loss of the LOD information a bad export setting in Motionbuilder or bad import setting in FBX? Is this a deficiency in the modelling tools? If so, what is the proper pipeline to create FBX models with LOD levels and multiple animation tracks?
Will
