FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
Missing texture in FBX file
8 REPLIES 8
Message 1 of 9
claustres
783 Views, 8 Replies
I wrote a FBX importer that retrieves materials based on the DisplayTexture.cxx example.
However, I cannot properly get the texture in the attached file (I also provide my code).
NOTE : I removed the vertex data from the file because it is too big, it is just given as illustration
but do not try to open it (I have the original file/texture if one needs it to test).
I am not a FBX expert but it seems that the texture is attached to the geometry and not the material
within the file. I don't know why, maybe it is a different way than usual to manage texture in FBX...
Nevertheless, if I convert the file to OBJ with the FBX converter the output is fine, i.e. the material has a map_Kd.
So I suspect my code does not cover all possible cases and I hope that someone can help me extend it.
Thanks in advance.
13841_MeagqOAEM8iIXIg1gDqN.zip
8 REPLIES 8
Message 2 of 9
in reply to: claustres
Why does this file crash the ViewScene.exe viewer from the 2006 FBX SDK?
Do all FBX files written with 2009.3 SDK now crash older viewers?
If so, why?
Message 3 of 9
I don't really have time to look into this, but I do know the latest SDK allows some pointers to be NULL, where previously there has always been a value. Many programs that aren't coded to check for valid pointers are crashing. Sorry I can't help more right now, but am buried in non-FBX work at the moment, and was just trying to catch up on messages during compiles 🙂
Message 4 of 9
The 2006 viewer program crashes when it calls the Import() function. All pointers are valid:
gImporter->Import(*gScene);
And both the 2006 and 2009 SDKs write out FBX 6.1.0 files, so the file format version has not changed.
Message 5 of 9
claustres
If so, why?
As I previously said take care that I removed the content of the vertex data within the file to make it smaller for posting.
Indeed, I think that my problem is related to texture connections and it should be sufficient for illustration of this.
However, I have the full original file if you'd like to test it, and I've just tested to zip it twice and it seems to be small enough now (without the texture file though), so here it is...
13873_zRY0q1cNkEuRq4hsNPEk.zip
Message 6 of 9
Ah, you edited the file! Well, I guess that explains it. 🙂
Message 7 of 9
eric720
Hi Luc,
I checked your file in ImportScene sample and max importer, and there is no problem. Also, the texture is attached
to the geometry node is normal in the file. Because the SDK with process the scene after importing and "push" the
textures to cooresponding properties in material.
So the file has no problem, and I suggest u to double check your code on convertMaterialToXML.
I am not sure how you get your material, but here is the code in DisplayTexture.cxx
KFbxProperty lProperty;
int lNbMat = pGeometry->GetNode()->GetSrcObjectCount(KFbxSurfaceMaterial::ClassId);
for (lMaterialIndex = 0; lMaterialIndex < lNbMat; lMaterialIndex++)
KFbxSurfaceMaterial *lMaterial = (KFbxSurfaceMaterial *)pGeometry->GetNode()->GetSrcObject(KFbxSurfaceMaterial::ClassId, lMaterialIndex);
bool lDisplayHeader = true;
if(lMaterial){
//Diffuse Textures
lProperty = lMaterial->FindProperty(KFbxSurfaceMaterial::sDiffuse);
FindAndDisplayTextureInfoByProperty(lProperty, lDisplayHeader, lMaterialIndex);
However, I cannot properly get the texture in the attached file &#40;I also provide my code&#41;.
but do not try to open it (I have the original file/texture if one needs it to test&#41;.
Thanks in advance.
Message 8 of 9
claustres
I was retrieving the material through the layer elements, I will try to use property connections instead but what is the difference actually ?
Message 9 of 9
luc.vovan
Actually from 2006.11 to 2009.1 we have changed how the materials and textures are connected. They are now connected to the node instead of simply the scene!
Cheers,
Luc
