Well, clone a static mesh is easy, but how to clone a skinned mesh? the cloned mesh should share the same skeleton with the original mesh, my purpose is making a LOD mesh for the original mesh.
I cannot figure it out, can anybody advice me?
Here is my code:
// clone the attribute FbxNodeAttribute* cloned_attribute = (FbxNodeAttribute*)a_pNode->GetNodeAttribute()->Clone(); // clone the node FbxNode* cloned_node = (FbxNode*)a_pNode->Clone(); // attach the attribute to the node cloned_node->SetNodeAttribute(cloned_attribute); // add the cloned node to the parent node a_pNode->GetParent()->AddChild(cloned_node);
Solved by artgolf1000. Go to Solution.
Found a solution:
If in the same scene, I can use:
FbxNode* cloned_node = (FbxNode*)FbxCloneManager::Clone(a_pNode);
If in the cloned scene, it will lose animation connections, becomes static mesh, and it may crash when loading.
Conclusion: Always works in the same scene.
The following code is from Robert Goulet:
Here is a sample code that demonstrate how to do it using the FBX SDK:
// Prepare the FBX SDK.
InitializeSdkObjects(lSdkManager, lScene);
// Load the scene.
lResult = LoadScene(lSdkManager, lScene, lInFile.Buffer());
// Get the mesh we want to clone (we assume it is the first node attribute connected to the node)
FbxNode* lNode = FbxCast<FbxNode>(lScene->FindSrcObject("pCylinder1"));
if (lNode)
// Get the mesh to clone as the FbxGeometry (all the methods we need to call are here so no
// need to get the FbxMesh)
FbxGeometry* lsrc=FbxCast<FbxGeometry>(lNode->GetNodeAttribute());
// clone the mesh (and all its deformers. This is implicit and cannot be bypassed)
FbxGeometry* lClone = FbxCast<FbxGeometry>(lSrc->Clone(FbxObject::eDeepClone));
// But we can freely destroy the cloned deformers
for (int d = lClone->GetDeformerCount()-1; d >= 0; d--)
lClone->GetDeformer(d)->Destroy();
// and re-connect using the deformers from the source mesh
for (int d = 0; d < lSrc->GetDeformerCount(); d++)
lClone->AddDeformer(lSrc->GetDeformer(d));
// --- Done! ---
// From this point, it is simply to validate that we have a different cloned mesh
// still connected to the original deformers.
// change vertices positions of the cloned mesh
int nbCtrlPts = lClone->GetControlPointsCount();
FbxVector4* lCtrlPts = lClone->GetControlPoints();
for (int i = 0; i < nbCtrlPts; i++) lCtrlPts[i] *= 2.0;
FbxNode* lN1 = FbxNode::Create(lScene, "cloned");
lN1->AddNodeAttribute(lClone);
lScene->GetRootNode()->AddChild(lN1);
// Save the scene.
lResult = SaveScene(lSdkManager, lScene, lFilePath.Buffer(), ASCII);
// Destroy all objects created by the FBX SDK.
DestroySdkObjects(lSdkManager, lResult);
