FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
biped and bones rotation issues
1 REPLY 1
511 Views, 1 Reply
hi
i'm a new FBX SDK 2014 user and i'm facing the issues described in the object.
i have an FBX file with a biped in the simplest form.
in the pic you can see what i obtain (left is fbx viewer,right mywindow)
if i draw the skeleton with the EvaluateGlobalTransfrom for every FbxSkeleton node (as in the demo) all is drawed correctly, but i can not understand why with the local matrix (the node rot and pos) result is so weird.
This is my (wellknown standard) drawskeleton routine:
void DrawHierarchy(Bone* root)
     glPushMatrix();
          glTranslatef(b->pos[0], b->pos[1], b->pos[2]);
          glRotatef(b->rot[0], 1.0f, 0.0f, 0.0f);
          glRotatef(b->rot[1], 0.0f, 1.0f, 0.0f);
          glRotatef(b->rot[2], 0.0f, 0.0f, 1.0f);
          glBegin(GL_LINES);
               glVertex3f(0.0f ,0.0f ,0.0f);
               glVertex3f(c.pos[0],c.pos[1],c.pos[2]);
          glEnd();
         for(int i=0;i<b->nchilds;i++)
              DrawHierarchy(b->childs[i]);
     glPopMatrix();
Any suggest for this issue?
thank you
Ele
1 REPLY 1
solved by changing rotation order.
thank you for your time
