I'm using a bat file to start up maya, open an fbx, [stuff], and export.
There are many cases of maya crashing on import of the fbx files. It is very inconsistant when it happens. On the same file in the same circumstances (as far as I can tell) it sometimes works and sometimes crashes.
Heres one of the crash logs - they are all quite similar:
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x33558010
Fault address: 31A3CAE1 in C:\Program Files (x86)\Autodesk\Maya2012\bin\plug-ins\fbxmaya.mll
0001:0009BAE1 Logical offset (see .map file for location)
Registers:
EAX:335103E0
EBX:000023E1
ECX:71A9311F
EDX:35CBC7A8
ESI:00047C20
EDI:1BC053C0
CS:EIP:0023:31A3CAE1
SS:ESP:002B:0164DAA8 EBP:0164DBA8
DS:002B ES:002B FS:0053 GS:002B
Flags:00010206
Call stack:
(0) section:offset Address Frame
0001:0009BAE1 0x31A3CAE1 0x00000000
Module: C:\Program Files (x86)\Autodesk\Maya2012\bin\plug-ins\fbxmaya.mll (-exported-)
Location: fbxsdk_2013_3::FbxTrimNurbsSurface::GetFlipNormals + 0x14B31 bytes
Decl: public: bool fbxsdk_2013_3::FbxTrimNurbsSurface::GetFlipNormals(void)
(1) section:offset Address Frame
0001:000B1760 0x31A52760 0x00000000
Location: fbxsdk_2013_3::FbxTrimNurbsSurface::GetFlipNormals + 0x2A7B0 bytes
(2) section:offset Address Frame
0001:000B1F99 0x31A52F99 0x00000000
Location: fbxsdk_2013_3::FbxTrimNurbsSurface::GetFlipNormals + 0x2AFE9 bytes
(3) section:offset Address Frame
0001:000D00BE 0x31A710BE 0x00000000
Location: fbxsdk_2013_3::FbxTrimNurbsSurface::GetFlipNormals + 0x4910E bytes
(4) section:offset Address Frame
0001:00062C1B 0x73AD3C1B 0x00000000
Module: C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.8387_none_5094ca96bcb6b2bb\MSVCR90.dll (-exported-)
Decl: free
(5) section:offset Address Frame
0001:00062C3A 0x73AD3C3A 0x00000000
Decl: free
Next frame pointer is missing - is /Oy turned on in this module?
//crash file = C:\Users\ADMINI~1\AppData\Local\Temp\2\MayaCrashLog141028.2240.log
//version = 2011.07.28.0800
//cut = Thu 07/28/2011, 201107280800
//last tool: renderWindowSelectContextItem
//panel with focus: modelPanel4
//visible panels:
// modelPanel4
//Memory usage:
// 2048.000 Mb Free Memory
// 2048.000 Mb Free Swap
// 691.395 Mb Current
// 36.685 Mb Arrays
// 0.129 Mb arguments
// 35.000 Mb MEL
// 0.124 Mb Transforms
// 0.159 Mb Object Arrays
// 0.313 Mb Data Blocks
