I've nearly finished establishing a proper FBX to UDK (Unreal Development Kit) pipeline that allows us to effectively assign materials, behaviors, etc but I have one last hitch: node (?) naming. I'm very new to the FBX SDK but if absolutely necessary, I'll learn the SDK and cook up a converter to help with this (although I hope it won't be necessary).
The problem is when importing FBX into UDK, you have a couple of options:
1) Isolate common objects (i.e., interior walls) in authoring software and export to FBX; in UDK select combine meshes. However, with many shapes and configurations, the collision and texture application is... unreliable, leaving us to have to recreate the meshes inside of UDK. That's too much time.
2) Import every object independently, place one by one into UDK. I've written a little app that attempts to place the objects as they were in the original software and works reliably except most of the object names created by the exporter contain characters illegal inside of UDK (e.g., Wall Generic - 8" ).
Any tips on reconfiguring/redefining the naming? Otherwise, the next step in option 2 is to rename each and every object... hundreds or thousands of them.
