Area :: Header
New tools, templates and workflows
Announcing Extension 2 for 3ds Max 2015 and 3ds Max Design 2015
Discussion Groups
FBX Plug-ins Import-Export Discussions
0 Kudos
FBX plug-in 2012.2 failed to initialize in 3DSMax.
175 Views, 2 Replies
02-01-2012 05:43 AM
I installed the 2012.2 fbx plugin on 3ds max 2010 32bit. but when I boot the max, it failed to load the fbx plugin, it says:
“failed to initialize Error code 127”
my system is windows7 64bit, the max already installed sp1.
Somebody help me~~~
Distinguished Contributor
0 Kudos
Re: FBX plug-in 2012.2 failed to initialize in 3DSMax.
02-02-2012 05:46 AM in reply to: diosama
Hello diosama,
I am unable to reproduce your problem. Could you please tell us the following:
1. At what point do you get the 3dsmax.exe error? Does Max UI open up and then crash?
2. When exactly do you get the initialization error? If Max does start, what do you see in the plug-in manager next fbxmaya.dul?
3. Can you give us the steps you do to get the problem? That we can have a better idea on how to duplicate your problem.
In the meantime, I would uninstall the plug-in you have and try again with a new install. You can find the plug-in here:
http://images.autodesk.com/adsk/files/fbx20122_3dsmax2010_win.exe
Carlos
0 Kudos
02-02-2012 07:06 PM in reply to: diosama
Hello CarlosC,
Thank you for the new plug-in file, it works well!
and thanks again.
