FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
error output in script editor?
2 REPLIES 2
396 Views, 2 Replies
Is there a way to grab any errors that an export generates, within Maya? (instead of accessing the log file). Are they output to a string that can be easily accessed?
Error: Unsupported Operation on Mesh Vertices
The plug-in has detected mesh nodes with unsupported operators that affect the vertex and/or face count. To correct this, delete the Non-deformer history before exporting. The following nodes will not be processed:
pCube1
Thanks!
2 REPLIES 2
Hello patconnole,
Unfortunately, there is no mechanism to access them within Maya. They are logged to the file so your best bet is to parse this file.
Carlos
Thanks for the response! I've decided to just wipe the file, export, then read its content with every export.
With python, I'm using this to find the log:
os.path.expanduser('~/maya/FBX/Logs/2012.1/maya2012exp.log')
