FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
shortname of .liw being lost in FBX export?
3 REPLIES 3
894 Views, 3 Replies
Hi there,
I'm a newbie poster that thought you should about an issue I encountered the other day, using the latest FBX importer/exporter in Maya 2012 (hotfix 2 x64).
Basically when I export a skinned character model from Maya to FBX and then import it back into Maya I can't use maya's paint skin weights tool on it. It comes up with an error saying it can't find the .liw attribute in the character's bones. This error occurs because the skinClusterInflMenu.mel script uses the short name for the attribute, while it appears the process of exporting to FBX removes the shortname of the lockInfluenceWeights attribute, leaving only an attribute called .lockInfluenceWeights and not .liw.
I just adjusted the skinClusterInflMenu.mel script to use the long name too and the paint skin weight tool works again.
I just thought you should know.
or am I missing setting an option in the FBX exporter/importer?
3 REPLIES 3
Hello Mike!
Thank you for the information. We are aware of that particular issue and it has been dealt with. The fix will be available in upcoming versions of the plug-in. As soon as it is released, I will post more information.
If you find anything else, don't hesitate to let us know.
Carlos
Has this been resolved yet?
Running Maya 2011(32 & 64 bit) at work and came across this. Same thing. Imported from an FBX.
Thanks.
Matt -
Hi mttjss,
Yes, the fix was introduced in 2013.0, if you go to the FBX plug-in download page, you can get version 2013.1.
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775855
Carlos
