I encountered the exact same problem as a previous post http://forums.autodesk.com/t5/fbx-forum/expected-unqualified-id/td-p/4220849
which is a compilation error "expected unqualified-id before numeric constant" in fbxobject.h, fbxnode.h, fbxtexture.h and fbxmanipulators.h on Ubuntu. I am using FBX SDK 1.2 and GCC 5.4.0. Like the discussion in the post, the cause is probably because the function name
PropertyNotify(EpropertyNotifyType pType, FbxProperty& pProperty)
in the fbx files has already been defined as a int value in X11/X.h. I am wondering if there is any solution or follow up to this issue. Thanks for reply.
