I want to change mappingtype.
FbxGeometryElement::eByPolygonVertex => FbxGeometryElement::eByControlPoint for UV.
RemapIndexTo( ) function is not surported.
How to change Mappingtype ?
thank you.
Solved by Numerator. Go to Solution.
Do you want to change the type on an FBX file you are reading or writing? If this is for reading, you are probably better off reading in the current format and converting to the format you need.
thank your answer.
I want to write the vertex information with control point.
when polygon vertex converting control point, Some Vertex is duplicated.
If I select texture coordinate then the artifact appear.
