FBX Forum
Welcome to Autodesk’s FBX Forums. Share your knowledge, ask questions, and explore popular FBX topics.
How to change Mappingtype ?
2 REPLIES 2
winstorms
467 Views, 2 Replies
I want to change mappingtype.
FbxGeometryElement::eByPolygonVertex => FbxGeometryElement::eByControlPoint for UV.
RemapIndexTo( ) function is not surported.
thank you.
2 REPLIES 2
Numerator
in reply to: winstorms
Do you want to change the type on an FBX file you are reading or writing?  If this is for reading, you are probably better off reading in the current format and converting to the format you need.
winstorms
in reply to: Numerator
thank your answer.
I want to write the vertex information with control point.
when polygon vertex converting control point, Some Vertex is duplicated.
If I select texture coordinate then the artifact  appear.
