Hi
Having real trouble stopping light leaking through places where geometry meets - see the bit in red outline of the attached.
Do any of the settings work in the spotlight parameters as I can't seem to get rid of the leaks.
If I move the spotlight closer it helps a little but shadows beyond around 10 meters vanish which is a problem.
Is there a way to change the size of the shadow map?
Do you know when the replacement viewer for FBX review will be released and will it solve this problem?
Rik Wilson
