I've been using Game Exporter for a month now and it's been a real lifesaver. Unfortunately, one of the files I'm working with has gotten to over 14 animations and I've found that Game Exporter .ini doesn't load more than 14.
[General] PresetName=StabilatorAnim PresetType=1 Animation=1 ASCII=0 AxisConversionMethod=1 BakeAnimation=0 BakeFrameStart=0 BakeFrameEnd=550 BakeFrameStep=1 BakeResampleAnimation=1 Cameras=0 CAT2HIK=0 ColladaTriangulate=1 ColladaFrameRate=30.000000 Convert2Tiff=0 ConvertUnit=0 EmbedTextures=0 FileVersion=FBX201400 FilterKeyReducer=0 GeomAsBone=1 GenerateLog=1 Lights=0 NormalsPerPoly=0 PointCache=0 Preserveinstances=0 Removesinglekeys=0 Resampling=30.000000 ScaleFactor=1.000000 ExportSet=0 Shape=1 Skin=1 ShowWarnings=0 SmoothingGroups=1 SmoothMeshExport=0 TangentSpaceExport=0 Triangulate=0 UpAxis=0 UseSceneName=0 SelectionType=1 MultiFbxFiles=0 FBXReview=0 Path=C:/projectFiles/MaxProjects/VMT_M/export/Animations Filename=Stabilator [AnimationClip 00] TakeIndex=0 TakeName=CenterCoverRemove StartFrame=60 EndFrame=105 Enabled=1 [AnimationClip 01] TakeIndex=1 TakeName=RaiseLeftStab StartFrame=160 EndFrame=210 Enabled=1 [AnimationClip 02] TakeIndex=2 TakeName=InsertLeftStrut StartFrame=241 EndFrame=300 Enabled=1 [AnimationClip 03] TakeIndex=3 TakeName=RaiseRightStab StartFrame=350 EndFrame=400 Enabled=1 [AnimationClip 04] TakeIndex=4 TakeName=InsertRightStrut StartFrame=431 EndFrame=490 Enabled=1 [AnimationClip 05] TakeIndex=5 TakeName=ActuatorTest1 StartFrame=550 EndFrame=580 Enabled=1 [AnimationClip 06] TakeIndex=6 TakeName=RemoveECBracket StartFrame=610 EndFrame=695 Enabled=1 [AnimationClip 07] TakeIndex=7 TakeName=RemoveUBracket StartFrame=700 EndFrame=715 Enabled=1 [AnimationClip 08] TakeIndex=8 TakeName=RemoveLowerBolt StartFrame=720 EndFrame=815 Enabled=1 [AnimationClip 09] TakeIndex=9
It's clear from the .ini that they're still there, but Game Exporter won't load them, and whenever you close Max (I assume Maya as well) it clears your list. Is there a workaround for this bug?
Still unable to find a solution to this problem, and it's causing a real headache. Does anyone else have the same problem?
