I'm on a task that will require load fbx file on ios and android.
Q1. And I found seems FBX SDK doesn't have a version on android currently, I wonder if Autodesk have plan to
provide an android version of FBX SDK?(Or if you could provide FBX SDK source code I would be willing to port it to android)
Q2. So for now I could choose to convert fbx to obj and load obj file on android, I wonder if 100%
of content that in fbx could be exported to obj format?
Leon
Solved by kevinvandecar. Go to Solution.
Hello Leon,
For Q1: Unfortunately there are no plans to port the FBX SDK to work on Android at this time.
For Q2: Yes, the OBJ format cold be used for the mesh representation, and some material support. However, note that FBX format can contain additional properties, and also supports animation. OBJ format does not support those aspects, so 100% fidelity could not be maintained. If you only need certain aspects (mainly geometry), certainly OBJ could probably handle it. Depending on the source data, I would perform a variety of tests to ensure that it will work for you in majority of cases. Note that FBX SDK directly supports output to OBJ. See here: http://help.autodesk.com/view/FBX/2017/ENU/?guid=__files_GUID_0B122E01_7DB8_48E3_AADA_5E85A197FEE1_h...
hope it helps,
kevin
Hello Kevin,
Thanks for the answers.
If obj does not support animation, I think I'd better stick with fbx, is there a
specification on fbx text format?
Leon
Hi Leon,
Sorry, but we do not provide any file format specification for FBX. Our options for Android are limited.
Rather than OBJ, maybe the collada format wold work? That one is more complete and is open. Again, the FBX SDK can export to it.
Hope it helps,
kevin
